high-resolution screenshot tool can not record the 3D curves generated by graph
caihang1234
Post by caihang1234 »
Hi! When I use the high-reslution screenshot tool to record the robot and the 3D curves generated by a graph, the screenshot can not record the 3D curves, but I have already set the 'renderable' property of the graph. The verson is V4.1. Anyone can help me solve the problem? Thx very much!
Re: high-resolution screenshot tool can not record the 3D curves generated by graph
are you using the OpenGL3 renderer (i.e. with shadows)? If yes, then graph curves won't be displayed. Instead, you should generate a curve via shapes, using the script described in this reply.
