Go to Goal in matlab
guest
Post by guest »
Hi
What is the Matlab code to control the Pioneer mobile robot to reach the target point?
With how to use it
Please help me
Re: Go to Goal in matlab
you can move the robot by setting a target velocity for left and right wheel respectively (vLeft and vRight):
    sim.setJointTargetVelocity(motorLeft, vLeft)
    sim.setJointTargetVelocity(motorRight, vRight)
and you can measure error with respect to target (assuming there is a dummy in the target pose) with:
    pos = sim.getObjectPosition(targetDummyHandle, robotHandle)
    orient = sim.getObjectOrientation(targetDummyHandle, robotHandle)
(you would have x/y error -in robot's frame- in first two components of pos, and orientation error in last component of orient)
How to assign input velocities depends on the choice of your kinematic model.
Suggested reading: https://cs.gmu.edu/~kosecka/cs485/lec04-control.pdf
guest
Post by guest »
Thank you very much
But I need a complete code example of the Pioneer robot to make it completely clear
Please help me
I want a robot that tracks dummy with an algorithm potential field path planning
and It has the feature of avoiding obstacles
You need to break down the problem into the smaller problems, e.g.:
1) deriving the robot's kinematic model
2) inverting the kinematic model
3) defining the attractive and repulsive potential fields using distance calculation module
4) moving the robot to walk the gradient of the potential field
Can't give you a complete example, as that is too time consuming, and there are no examples for any of those points, but I think it is only a matter of applying textbook formulas.
If you find any difficulty with the above tasks, you can post more specific questions.
