Question about the physics of joints in simulations
fairytalef00
Post by fairytalef00 »
I wanted to analyze the 7 dof manipulator in the model browser.
What I'm curious about is that when I removed the script and simulated it, the manipulator's link did not rotate.
If I imagine, it was strange that Link was affected by gravity and had to rotate using the joint as the axis of rotation, but it just stayed still.
So I created a simple experiment to understand the principles that apply to joints.
https://1drv.ms/v/s!AuvU7BTQNjpWh_IyTUK ... Q?e=IRe0ho
Except for the joints and links to be verified, all other elements were removed as shown in the video.
I also copied this manipulator to create the exact same model. We will call this the test model.
In the test model, I removed the original joint and recreated a revolute joint whose position is equal to the axis of rotation.
When tested as shown in the video, the test model rotates as I imagined, but the preference model does not show any movement.
I exported the urdfs of the two models and compared the contents, and they were exactly the same.
Why does it look like this?
Are there more features I don't know about?
Re: Question about the physics of joints in simulations
we cannot see the video you posted.
Keep in mind that a joint can be in kinematic or dynamic mode. And when in dynamic mode, it can be in one of following control mode: free, force, velocity, position, spring or custom.
Most manipulator joints are in dynamic mode, and in position control: so even if you remove the script controlling that robot, your joints should still hold their position.
fairytalef00
Thank you for your reply.
I've fixed the video again so you can see it.
https://1drv.ms/v/s!AuvU7BTQNjpWh_IyKCQ ... g?e=cbQQ74
Of course, even if you didn't watch the video, I knew what the problem was thanks to your answer.
The original example, the 7 Dof manipulator, was set to 'dynamic mode - position target 0' so it was supposed to keep its original position.
It's a small thing, but I'm so glad I figured it out.
Many thanks.
