how to find the center of mass of a assembly
sunihsn
Post by sunihsn »
i have built the quadruped robot using a cad tool and i have imported it to coppeliasim, know i want to find the COM of the robot so that i can capture the acceleration, velocity and position of the center of mass. how to do it can you pls explain the procedure for it ?
Re: how to find the center of mass of a assembly
The center of mass \(\mathbf{C}\) of a composite body is given by the weighted average of the individual centers of mass, i.e.:
\(\mathbf{M} = \sum_{i=1}^{n} m_i\)
\(\mathbf{C} = \frac{1}{\mathbf{M}}\sum_{i=1}^{n} m_i \cdot \mathbf{c}_i\)
where \(m_i\) is the mass of the i-th body, and \(\mathbf{c}_i\) its center of mass in global coordinates.
To retrieve \(m_i\) and \(\mathbf{c}_i\) the functions to use are sim.getShapeMass and sim.getShapeInertia, e.g.:
local shapes = {shape1handle, shape2handle, ...}
local M = 0
local C = Vector {0, 0, 0}
for i, shape in ipairs(shapes) do
    local m = sim.getShapeMass(shape)
    M = M + m
    local ii, com = sim.getShapeInertia(shape)
    local c = Matrix(3, 4, com):col(4) -- 4th column of com is the position of center of mass
    c = sim.multiplyVector(sim.getObjectMatrix(shape), c) -- in global coords
    C = C + m * c
C = C / M
sunihsn
Post by sunihsn »
https://drive.google.com/file/d/1ySF7z- ... sp=sharing
i am couldn't able t get the com value , can you pls help me atleast for one leg . i have added a child script to the code in which i have coded using ur example. and the result is : "Center of Mass for Leg 1:",{-nan(ind), -nan(ind), -nan(ind)}
"Center of Mass for Leg 2:",{-nan(ind), -nan(ind), -nan(ind)}
"Center of Mass for Leg 3:",{-nan(ind), -nan(ind), -nan(ind)}
"Center of Mass for Leg 4:",{-nan(ind), -nan(ind), -nan(ind)}
You are not accessing objects correctly.
See Accessing scene objects programmatically.
sunihsn
Post by sunihsn »
https://drive.google.com/file/d/1qrZW4s ... sp=sharing
i have done adding the handles for the objects but now if i change the shape reference frame the COM values are changing. what is the correct way of doing it ?. or any changes is require in the model.
your calculation of "totalCenterOfMass" is not correct.
you probably want to do:
local allHandles = {
    body,
    hip_1, upper_dynamic1, Dynamic_lower_leg1,
    hip_2, upper_dynamic2, Dynamic_lower_leg2,
    hip_3, upper_dynamic3, Dynamic_lower_leg3,
    hip_4, upper_dynamic4, Dynamic_lower_leg4,
local totalCenterOfMass = calculateCenterOfMass(allHandles)
sunihsn
Post by sunihsn »
https://drive.google.com/file/d/1_ZGjA2 ... sp=sharing
hi, thank you for identifying the problem . now even after correcting that, the center of mass is far away from the body of the robot . i checked the mass of all the objects like, legs and body its all coming correct . what do you think the reason could be ?, i have chosen shape reference as the mesh center. apart from that any other suggestion for making the model for dynamics use is appreciated.
Thank you
The error is in the code to transform the c (shape center of mass) vector in global coords.
You first have to extract the position vector, and then transform it using sim.multiplyVector:
local ii, com = sim.getShapeInertia(shape) -- Get inertia and center of mass
local c = {com[4], com[8], com[12]} -- Extract position of center of mass
c = sim.multiplyVector(sim.getObjectMatrix(shape, -1), c) -- Transform to global coords
Have also a look at the model models/tools/center of mass visualization tool.ttm
sunihsn
Post by sunihsn »
https://drive.google.com/file/d/1JJFscw ... sp=sharing
i have corrected it as you have explained . can you pls check or verify if its correct or not , still i am not getting the expected results in co-simulation.
and also how to give these values: Frictional Force
Coefficient of Static Friction=mu_s=0.9;
Coefficient of Dynamic Friction=mu_k=0.7;
Critical Velocity=mu_vth=0.01;
contact_stiffness=500;
contact_damping=50;
how to give and where to give it , any specific dynamics simulator you suggest for this like bullet, newton , MUjuco etc?
