About the rope in coppelisim
ZnMnCr
Post by ZnMnCr »
The recently added MUJOCO engine enables the connection of ropes between dummies. It is an exciting feature. How can I control the length of this rope? Thanks。
Re: About the rope in coppelisim
have a look at the demo scene scenes/mujoco/stringsRopesClothsAndSoftBodies.ttt:
Following are the steps required:
  • Create a prismatic joint
  • Create 2 dummies
  • In the dummy dialog, set the dummy type to Dynamic, tendon constraint
  • Set the linked dummy to the other dummy
  • Click Engine properties and for mujoco/jointProxy/joint, set the path to the proxy prismatic joint
  • In the joint dynamics dialog, set Spring for the control mode. Adjust the spring constant K and C appropriately
  • Now you can change the tendon length via the prismatic joint, with sim.setJointTargetPosition
