VHACD -> CoACD?
zorro
VHACD -> CoACD?
Post by zorro »
Hello!
I am trying to make a peg-in-hole scene, it seems the CoACD has better performance than VHACD in decomposing non-convex shapes. Will you guys consider adding this module into CoppeliaSim? I believe the addition of this component would greatly assist tasks with complex mechanical characteristics.
Here are some related links for CoACD:
https://github.com/SarahWeiii/CoACD
https://arxiv.org/pdf/2205.02961.pdf
Re: VHACD -> CoACD?
you can already use CoACD with following Python script (e.g. as a CoppeliaSim embedded script):
# python
import numpy as np
import coacd
def getConvexDecomposed(shapeHandle):
    p = sim.getObjectPose(shapeHandle)
    vertices, indices, normals = sim.getShapeMesh(shapeHandle)
    vertices = sim.multiplyVector(p, vertices)
    vertices = np.array(vertices).reshape(-1, 3)
    indices = np.array(indices).reshape(-1, 3)
    mesh = coacd.Mesh(vertices, indices)
    parts = coacd.run_coacd(mesh, threshold = 0.02) # a list of convex hulls.
    newShapes = []
    for p in parts:
        vert = p[0].flatten().tolist()
        ind = p[1].flatten().tolist()
        newShapes.append(sim.createShape(0, 0.0, vert, ind))
    return sim.groupShapes(newShapes)
def sysCall_init():
    sim = require('sim')
    h = sim.getObject('/path/to/shape')
    convexDecomposedCompound = getConvexDecomposed(h)
We might add an add-on in next release for that.
