Java ZMQ Remote API
lumeqi
Re: Java ZMQ Remote API
Post by lumeqi »
Thank you, I can only create one sim. I have previously tried to control the opening and closing of the gripper through "setInt32Signal" and it was successful. But I don't know how to pass a callback function when using sim.moveToConfig.
In Example.java, I saw registering a callback function, but I didn't find out how to use it.
lumeqi
Post by lumeqi »
public class Example {
    public Example() {
    public static Object[] myFunc(Object[] items) {
        Object[] retVals = new Object[]{21};
        return retVals;
    public static void main(String[] _args) throws IOException, CborException {
        RemoteAPIClient client = new RemoteAPIClient();
        RemoteAPIObjects._sim sim = client.getObject().sim();
        client.registerCallback("myFunc", Example::myFunc);
        sim.setStepping(new Object[]{true});
        sim.startSimulation(new Object[0]);
        double simTime = 0.0;
        while((simTime = sim.getSimulationTime(new Object[0])) < 3.0) {
            System.out.printf("Simulation time: %.2f [s]%n", simTime);
            sim.step(new Object[0]);
        sim.stopSimulation(new Object[0]);
I know
used to register a callback, but where was this callback function called?
Sorry, I have another question. Does the callback function have to return data of type "Object []" and what is the meaning of this data.
client.registerCallback("configCallBack", ConfigCallBack::onCallBack);
sim.moveToConfig(
        -1, currentConfig, currentV, currentA,
        vel, accel, jerk,
        configs, targetV,
        ??, data, cyclicJoints, 0.0
If ConfigCallBack is the class I defined and onCallBack is the callback function in the class I defined, what should I write in the "??" position in my code? Thanks.
Make sure to use the latest version of CoppeliaSim. You are using an old version.
In the latest version of Example.java there are more examples.
About your other question: Object[] is an array of Object which is the superclass of all types, indicating a no better specified type.
Object[] is used as a return argument in Java as it is the only way to return multiple values from a function.
lumeqi
Post by lumeqi »
Thanks! I'm sorry to bother you again. I saw the code for calling the callback function:
Long retVal = sim.testCB(21,"myFunc@func",42); // sim.testCB is calling back above "myFunc"
But may this method not be used for parameter passing? Because the sim.testCB method returns a value of type Long, when I write code like this, I get an error:
Java. lang. RuntimeException: C:/.../lua/sim.lua: 712: attempt to call a number value (local 'callback')
My code (Where "configs" and "joints" are the parameters I passed.):
sim.moveToConfig(
                vel, accel, jerk,
                configs, targetV,
                sim.testCB(configs, "configCallBack@func", joints), joints, cyclicJoints, 0.0
Perhaps the sim.testCB function can only be called directly and cannot be passed as a parameter. So what should I do? (I have downloaded and checked the latest version of the code)
lumeqi
Post by lumeqi »
I found a solution in the source code, and I should pass the callback function as a parameter as follows:
sim.moveToConfig(
                vel, accel, jerk,
                configs, targetV,
                "configCallBack@func", joints, cyclicJoints, 0.0
I tried to write it as "configCallBack" before, but it failed. It seems to be because the suffix "@func" needs to be added.
