Java ZMQ Remote API
Java ZMQ Remote API
I want to connect CoppeliaSim in the SpringBoot project. How do I use the Java ZMQ Remote API?
I found an example in "programming \ zmqRemote API \ clients \ Java", but I cannot solve the problem that appears in the example.
Do I need to copy the code under "programming \ zmqRemote API \ clients \ Java \ src \ main \ Java \ com" to my own project when using it, so that I can create objects of the "RemoteAPIClient" class?
Where is the "RemoteAPIObjects" class? Is it a file in the template directory? But it doesn't look like a normal Java class.
Could you please provide an example of a Java ZMQ Remote API that runs without errors? Thank you very much.
My CoppeliaSim version is 4.6.0, Windows 11
Re: Java ZMQ Remote API
First of all, thank you very much for your help.
I roughly understand that I need to package the project provided by CoppeliaSim before using it.
(1) I modified the content under the<Python3-EXECUTABLE>tag corresponding to the Windows operating system in the provided pom.xml
(<Python3_EXECUTABLE>C:\Users\LMQ\.conda\envs\py39-cuda116\python.exe</Python3_EXECUTABLE>)
(2) I added COPPELIASIM_ROOT_DIR=C:\bed\CoppeliaSim_Edu_V4_6_0_rev10_Win to the system's environment variables
(3) Then enter the C:\bed\CoppeliaSim_Edu_V4_6_0_rev10_Win\programming\zmqRemoteApi\clients\java directory, select the corresponding Conda environment, and execute:
mvn package -DGENERATE_INCLUDE_OBJECTS=sim,simIK
But after executing step (3), the cmd got stuck. Is the process I followed correct? I'm very sorry to disturb you.
I have successfully packaged the project, but when using it, I am not sure if the parameter types I passed are correct. For example, when passing a List in Python, I am not sure if I should pass a List (or ArrayList) or a regular array in Java. Do you have any relevant reference materials? Thank you very much for your help.
If a
There are a couple of examples in zmqRemoteApi/clients/java/src/main/java.
list
is used in Python, in Java that would be List<T>
, with T
being the type of the elements of the list.There are a couple of examples in zmqRemoteApi/clients/java/src/main/java.
Do you know how to pass a callback function in Java clients? I tried for a long time but couldn't find a solution. I found the convertArg function in the "RemoteAPIClient" class, which specifies the type of parameter passed (objects that cannot pass custom interface implementation classes):
I really don't know how to solve this problem, so I am seeking your help. My code is:
I don't know how to avoid my callback function being converted to null. What should be passed as the position of the callback function parameter in moveToConfig? The error I always receive is:
Code in Example:
Is it related to my question? But I don't know how it is used.
Please! I really need help with this issue. Thank you very much!
else {
return arg.getClass().isArray() ? this.convertArg((byte[])arg) : null;
RemoteAPIObjects._sim simT = getClient().getSim();
ConfigCallBack callback = (configs1, vel1, accel1, sim) -> {
int i = 0;
for (int joint : joints) {
if (sim.isDynamicallyEnabled(joint)) {
sim.setJointTargetPosition(joint, configs1.get(i));
} else {
sim.setJointPosition(joint, configs1.get(i));
i++;
this.getClient().getSim().moveToConfig(
-1, currentConfig, currentV, currentA,
vel, accel, jerk,
configs, targetV,
callback, simT, cyclicJoints, 0.0
sim.lua:712: attempt to call a nil value (local 'callback')
Client.registerCallback ("myFunc", Example::myFunc);
"simT" is an object of the "RemoteAPIObjects._sim" class, and what I want to call is sim.moveToConfig. "this.getClient().getSim()" represents an object of the "RemoteAPIObjects._sim" class. However, I have encapsulated it according to my own task, and I can obtain the object of the "RemoteAPIObjects._sim" class normally.
The most important thing is that I don't know how to pass one of the parameters (the callback function) in sim.moveToConfig in the Java client.
The point is that
just wanted to make sure wether you understand the Java ZMQ remote API client interface...
sim
, simT
and the result of RemoteAPIClient.getSim()
are all the same thing which you are fetching three times.just wanted to make sure wether you understand the Java ZMQ remote API client interface...
in the same 'Example' code there is an example of registering and then calling a callback.lumeqi wrote: ↑06 Apr 2024, 06:40I don't know how to avoid my callback function being converted to null. What should be passed as the position of the callback function parameter in moveToConfig? The error I always receive is:Code: Select all
ConfigCallBack callback = (configs1, vel1, accel1, sim) -> { int i = 0; for (int joint : joints) { if (sim.isDynamicallyEnabled(joint)) { sim.setJointTargetPosition(joint, configs1.get(i)); } else { sim.setJointPosition(joint, configs1.get(i)); } i++; } }; this.getClient().getSim().moveToConfig( -1, currentConfig, currentV, currentA, vel, accel, jerk, configs, targetV, callback, simT, cyclicJoints, 0.0 ); ...
Code in Example:Code: Select all
Is it related to my question? But I don't know how it is used.Code: Select all
