Can't resume simulation after pausing in stepping mode with python-zmqremoteapi
Posted: 25 Apr 2024, 16:52
by tkschuler
I can't figure out a way to resume simulation in stepping mode. This seems to be a bug to me.
I'm using coppeliaSim 4.6 rev 18 on Ubuntu 22.04 and coppeliasim-zmqremoteapi-client v2.0.4.
For this simple test, I'm using the default empty scene.
#python
#sim.setStepping(True)
while True:
    sim.startSimulation()
    print("Started Simulation")
    time.sleep(1)
    i=0
    print("stepping")
    while i < 100:
        i+=1
        print(i, sim.getSimulationTime())
        #sim.step()
    sim.stopSimulation()
    print("paused simulation")
    time.sleep(1)
If stepping mode is commented out, this script runs fine. If stepping mode is initialized (either once, or every time within the loop), the script runs with sim.stop() but not sim.Pause(). With sim.pause, the simulation will run through 1 loop, then get stuck at i=2 every time.
Re: Can't resume simulation after pausing in stepping mode with python-zmqremoteapi
Posted: 29 Apr 2024, 10:13
yes, that is right. The sim.pauseSimulation API command actually only makes sense if there is some interaction with the user afterwards, otherwise there is no need/reason to pause a simulation: instead, simply do not step anymore and the result is the same.
However, try to add
function sysCall_suspended()
    return sysCall_nonSimulation()
to addOns/ZMQ remote API server.lua
Let me know.
