python API function; joint name ambiguity
eason
Post by eason »
Hello CoppeliaSim,
I am using CoppeliaSim Edu 4.6.0. I’d like to control the spherical joint of mannequin using python API. which function can I use, like the code strat with "sim.simx..."? And the joints of mannequin in scene huerarchy have the same name. How can I get the handlle of a specific joint with "sim.simxGetObjectHandle()" function?
Thank you very much.
Best regards
Eason
Re: python API function; joint name ambiguity
Remote API: https://manual.coppeliarobotics.com/en/ ... erview.htm
The function to use is sim.getObject (see the example in the above page).
eason
Post by eason »
Dear fferri,
Thank you for your guidance. I'd like to share the details of my solution:
1. In python API, simxSetSphericalJointMatrix is used to control spherical joint with 12 values.
2. The name and properites of the selected object are listed in the rendering window instead of scene hieratrchy.
Regards
Eason
I highly recommend to use the ZeroMQ remote API, instead of the legacy remote API: the ZeroMQ remote API is much more flexible, easier to use, and faster. Additionally, it covers all API functions you'd also use from within CoppeliaSim.
