vrep.exe has stopped working
Posted: 13 Mar 2014, 17:50
by ritesh_panchal
I have installed V REP PRO EDU on my HP550 Laptop with windows 8 installed.
But every time i try to open software it stopped with "vrep.exe has stopped working" message. And in cmd type windows a message "Add-on Script 'v-repAddOnScript-addOnScriptDemo.lua' was loaded" is appear.
Please help me regarding this issue.
Re: vrep.exe has stopped working
Posted: 14 Mar 2014, 11:14
that is a strange error.
Do you have
Simulator launched displayed in the console?
Can you try to launch it with:
and see what happens?
Posted: 14 Mar 2014, 17:16
by ritesh_panchal
Thanks for the Reply..
I tried your command. But it also failed to open program.
I have attached result of command execution in cmd.
Please do some help..
Posted: 14 Mar 2014, 18:00
No, actually that is good: you started V-REP in headless mode, ran the simulation for 5 seconds, then automatically quit V-REP again. Everything looks fine.
So that makes me think your problem is linked to the graphic card, or the GUI.
Can you enable all the debug items in the file v-repDir/system/usrset.txt, then launch V-REP normally and show us the debug output?
Posted: 14 Mar 2014, 18:07
by ritesh_panchal
Thanks for the suggestion.
I installed the older version of graphics driver and the Problem solved...
Thanks for the support...
