Kinematic and Dynamic parameters
Where to get the kinematic and dynamic parameters of the robots provided in V-Rep (IRB 140, for instance)?
Re: Kinematic and Dynamic parameters
what parameters are you refering to?
As an example, you can check a shape's dynamic parameters (such as mass, inertia, material, etc.) in the shape dynamic properties. You can also set/get some of those parameters via the API (e.g. simSetShapeMassAndInertia).
What about the geometric properties of the links/joints (e.g., length, diameter, etc.)? Thanks.
Check out following:
Do I have to write a code to get them. Can't I get them through the user interface?
You can also use the user interface for that of course. You can import, export, create objects, change parameters, etc.
You missed my point. What I meant was if I work with any of the manipulators that come with V-REP (say IRB 140, for instance) and I want to know the length of link 1, for example, how can I do that from the user interface? But I finally got it. I just have to see the bounding box under "view/modify geometry". Thanks.
