Kinect and ROS
eozkucur
Kinect and ROS
Post by eozkucur » 28 Feb 2013, 19:00
I am trying to simulate Kinect in V-REP and obtain sensor_msgs::PointCloud2 or pcl::PointCloud<pcl::PointXYZRGB> from a ROS node. What is the best approach to do this?
When I add Kinect model to a scene, it includes a vision sensor which provides a depth image as sensor_msgs/Image or depth buffer as vrep_common/VisionSensorDepthBuff. How can I obtain the corresponding color image and register it with depth buffer to build pcl::PointCloud<pcl::PointXYZRGB> in a ROS node?
Thanks in advance
Ergin
Re: Kinect and ROS
Post by coppelia » 28 Feb 2013, 19:54
Have a look at the demo scene "rosTopicPublisherAndSubscriber.ttt" that comes with the default installation. In particular, inspect the child script attached to object "Vision_sensor". Following 2 instructions are of interest for you if you want to publish the image of a vision sensor:
-- Retrive the handle of the vision sensor we wish to stream:
visionSensorHandle=simGetObjectHandle('Vision_sensor')
-- Now enable topic publishing and streaming of the vision sensor's data:
topicName=simExtROS_enablePublisher('visionSensorData',1,simros_strmcmd_get_vision_sensor_image,visionSensorHandle,0,'')
You will have to set the correct name for the vision sensor of the Kinect model.
To send the depth map, it is very similar, something like:
topicName=simExtROS_enablePublisher('visionSensorDepthData',1,simros_strmcmd_get_vision_sensor_depth_buffer ,visionSensorHandle,0,'')
Vision sensors cannot (yet) directly produce a point cloud message, but that shouldn't be difficult to implement.
ktjolsen
Connecting a robot using ROS
Post by ktjolsen » 20 Jun 2013, 06:09
When you connect a robot using ROS, does that mean that the robot is connected via a cable and sits still while the software in the physical robot is simulated in V-REP?
For example, if I connect iRobot's Roomba via ROS, then Roomba will just sit next to the computer while the cleaning algorithm is implemented in the V-REP scene?
Thank you!
Re: Kinect and ROS
Post by coppelia » 20 Jun 2013, 10:11
When you use the ROS framework, you are free to do whatever you want:
  • You can have the real controller control the virtual robot. This is often used to improve a real controller and test the real robot offline.
  • You can have the real controller control the real robot and visualize its state on the virtual robot
  • You can have the virtual controller control the real robot
  • and so on...
In that sense, the V-REP ROS API is just a means of connecting two separate entities (e.g. the real controller with V-REP). Additionally, ROS can provide a lot of libraries. What you exactly do in the end it totally up to you.
cedric.pradalier
Re: Kinect and ROS
Post by cedric.pradalier » 09 Jul 2013, 12:56
If if this is still useful, I prepared a patch to the ROS stack that add a publisher for depth data from a vision sensor. The end result is a RGBD point cloud.
In my use case, I will simplify the kinect model to use a single camera and publish both the point cloud and the image from the same rendering.
The patch (against V-Rep 3.0.4) is available at http://ubuntuone.com/1Ie0gWPFWOXHDreFFAg4Cn
Note that in this version, the links to the plugin header files and source files are incorrect, so they would have to be corrected before compiling the package.
The patch also correct a minor bug in the laser publisher that affected the timestamp AFTER publishing the message.
Tested on ubuntu 12.04, 64 bits with ROS Fuerte.
I hope that helps.
Re: Kinect and ROS
Post by coppelia » 09 Jul 2013, 14:27
Thanks Cedric!
We'll try to integrate the patch for next release.
xelda1988
Re: Kinect and ROS
Post by xelda1988 » 15 Aug 2013, 11:44
Hey Cedric
I applied your patch, but in a LUA script v-rep doesn't know the constant:
simros_strmcmd_get_depth_sensor_data
which it should know know after applying the patch. The file where it should know from is v_repConst.h which is in some of the subdirectories of programming/.
I rebuilt v-rep 3.04 from source, but it somehow doesn't apply the changes, whats the problem?
Cheers, Alex
philotuxo
Re: Kinect and ROS
Post by philotuxo » 14 Sep 2013, 01:28
Hi Cedric,
I guess the version on github is already patched with the patch given in this thread, isn't it?
And could you supply a simple pointcloud publisher model/scene? I couldn't get the idea how to publish pointcloud via Vrep.
Merci,
Serhan
formica
Re: Kinect and ROS
Post by formica » 16 Sep 2013, 17:22
My question is simpler. :D
I'm new of ROS. How can I read a depth image streamed by the vrep model of kinect in ROS?
Which stack could be useful to this purpose?
Regards
formica
Re: Kinect and ROS
Post by coppelia » 16 Sep 2013, 18:38
Have a look at the source code of the V-REP ROS plugin, file ROS_server.cpp, message: sensor_msgs::PointCloud2. That's the data being streamed, so you will have to subscribe to it. Refer to the ROS and sensor_msgs::PointCloud2 doc for details.
