Can anyone tell me what do i have to do if i want to calculate the distance between a moving robot for example the pioneer p3dx and any obstacle around it for example a wall. Also how can i see the value on the simulation ?
I am guessing i need to use proximity sensors or already built in sensors in the robots for example pioneer p3dx has 16 ultrasonic sensors i think. Also what do i need to add in the code ? Please help.
Kind regards
Maruf
Calculating distance and printing it
Re: Calculating distance and printing it
Hello Maruf,
to compute the minimum distance between your robot and the environment, use the distance calculation module. Once you have registered a distance object, you can access it, read it and print the distance from a child script with:
Of course you can do something similar with proximity sensors.
handle=simGetDistanceHandle('myDistanceObjectName')
result,distance=simReadDistance(handle)
print(distance) -- prints the distance to the console
hello,
so i am trying to obtain similar data and i tried using the above steps as specified. But I am receiving error at the below statement (correct me if i am wrong):
DistHandle = simGetDistanceHandle('FrontLeg') --statement executed during initialization
What I think, the error is due to the use of wrong distanceobject name: 'FrontLeg'
In such a scenario, how to know which is the correct name and whether the name used is a legal name?
I see two potential problems:
- either you have misspelled the object name (it is case sensitive)
- either you have not understood how object handles are retrieved. Make sure to read this page
Hey, How do I calculate the distance that my bot has moved and display the distance so that I can use this data for future applications? I'm unable to get it done using simxGetDistanceHandle.
You need to give us more information. Where are you trying to get and display the distance? In V-REP or in an external application?
