Hello.
I am aware of joint custom control callback script, but it looks that it is aimed to position control mainly. I would like to implement a custom velocity control loop (and some more advanced stuff, but later). The output of velocity loop should be force/torque, but the callback is returning velocity and maximum allowed torque, which is not suitable for velocity control loop. Is there a way of implementing such a loop with existing API?
Thank you.
Custom velocity loop
Re: Custom velocity loop
I am not sure I understood you completely. If you want to control the velocity, what else do you need to specify than the desired velocity, and the motor torque/force?
At least, the phyiscs engines do not take any other input that these. But here you have several options:
- you can set a very large force/torque, and simply provide the desired velocity
- you can set a very large velocity, and simply modulate the force/torque
