Encirclement using decentralized multi-robot
Edmendes
Post by Edmendes » 17 Nov 2014, 00:32
Hi guys,
First of all, forgive my bad english =)
I'm trying to implement a entrapment/encirclement system using multiple robots.
The entrapment/encirclement consists in three robots orbiting a target (you can see an example here: http://postimg.org/image/cnta2pvzj/ ). I would like to know if is possible to do THIS system in a decentralized way using V-REP. In other words, each robot must be able to act independently in the environment and perform as a group, the particular action.
One example is here: https://www.youtube.com/watch?v=nGc33RpvM8I .
I started to use the V-REP yesterday and I have a lot of doubts about how to use it. Could you suggest me tutorials that teach how to program a robot to perform a circular path around a target, using sensors?
Thanks a lot!
Re: Encirclement using decentralized multi-robot
Post by coppelia » 18 Nov 2014, 00:25
your question is very broad and a little bit vague. What kind of locomotion system do the robots have?
But basically you are able in V-REP to have a controller on each of the robots, and act independently from each other. That type of controller can be implemented in various ways, for instance via a child script. At the same time the different robots (or controllers) are able to exchange data via various means (signals, wireless communication, tubes, etc.).
Edmendes
Post by Edmendes » 24 Nov 2014, 00:51
Ok, thanks for the answer! =)
Now I plan to accomplish this task in stages ... the first of it is to make a robot encircle any object. I am using for this task the bubbleRob (the same as the tutorial). That is, the robot will encircling a fixed cylinder, for example. In this way, the robot must be able to identify the cylinder and then be able to go around it.
I'm new and I have some difficulties with the programming part ...
Thank you for your attention.
Edmendes
Post by Edmendes » 06 Jan 2015, 18:26
Can someone help me? =/
Eric
Post by Eric » 06 Jan 2015, 19:03
well... a question more specific than can someone help me would be useful
Edmendes
Post by Edmendes » 06 Jan 2015, 22:28
I got it, for a while, tks
