Does anyone know how I can make the connection LIDA Framework with V-REP?
I'm starting a research project involving mobile robots and would make an implementation with artificial agents using the V-REP simulator.
How to connect to LIDA Framework with V-REP?
Re: How to connect to LIDA Framework with V-REP?
you have many possibilities to connect V-REP to external libraries/applications. Best would probably be to have a small plugin that does this. Have look in the programming folder which contains several project files for plugins. I suggest to do something similar as in programming/v_repExtVision. In next release (the one after V-REP 3.1.3) that plugin will also support the Velodyne sensor.
