Debugging: Check variable values during simulation
tumsimon
Post by tumsimon » 06 Dec 2014, 13:53
Hi coppelia,
I am wondering, if there is any way to check the values of variables and signals while simulation is running and paused. Is that in any way possible? Also, can I see, where in my code the simulation is at the moment?
Thank you.
Simon
Eric
Re: Debugging: Check variable values during simulation
Post by Eric » 06 Dec 2014, 17:24
Hi
There is no "debugger" embedded in V-REP, but a set of wisely placed "print" or "simAddStatusbarMessage" does the trick.
Eric
Post by coppelia » 07 Dec 2014, 15:03
you can also drag the model Models/other/signal monitor.ttm into the scene: you will be able to read the state of the various signals.
luberdis
Post by luberdis » 18 Dec 2018, 03:20
coppelia wrote:
07 Dec 2014, 15:03
I found this model but I did not understand how it is used to view the channels
