Proximity sensor XYZ orientation
krzmi
Post by krzmi » 31 Dec 2014, 14:55
I have a problem with proximity sensor XYZ orienation. When I'm adding new sensor its detection volume is directed along Z axis. Is it possible to reorient detection volume along other axis? All options in Edit -> Reorient bounding box menu are disabled. I can't also modify object geometry in Scene Object Properties dialog. Is there any other way?
Eric
Re: Proximity sensor XYZ orientation
Post by Eric » 31 Dec 2014, 16:08
why don t you rotate the sensor?
krzmi
Post by krzmi » 31 Dec 2014, 18:04
rotating sensor rotates also its own XYZ orienation. Ray is still oriented along its Z axis
Post by coppelia » 31 Dec 2014, 20:30
you can do following from a child script for instance:
	result,distance,detectedPoint=simReadProximitySensor(sensorHandle)
	if result>0 then
		local m=simBuildMatrix({0,0,0},{math.pi,0,0})
		detectedPoint=simMultiplyVector(m,detectedPoint)
