Remove from Group
curka
Remove from Group
Post by curka »
Hi!
I imported a model and i made a group unfortunately i don't know the way to remove from them.
I used: Make Last Selected Object Parent
so how can i remove the objects form the group?
Re: Remove from Group
Hello Curka,
what exactly did you do? With [menu bar --> Edit --> Make last selected object parent] you won't make a group: you will simply attach all selected objects to the last selected object (so this is parenting). You can use the undo functionality, or simply make the object orphan again ([menu bar --> Edit --> Make selected object(s) orphan]).
Grouping is only an operation that is allowed between shape objects: two (or more) shapes can be grouped to form a new shape. To ungroup a shape, do [menu bar --> Edit --> Grouping/merging -->Ungroup selected shapes].
curka
Post by curka »
Thank you it works! :)
