simGetPathCtrlPoint
sneaker
simGetPathCtrlPoint
Post by sneaker »
it would be nice to have a function to get the position and orientation of a certain control point on a path.
something like:
table_3 position,table_3 euler_angles=simGetPathCtrlPoint(number pathhandle, number index)
Background:
I import a path from a CAM software and then do collision check, robot reach check and postprocess each point to real robot code by writing to a file with lua.
If i use simGetPositionOnPath I have to set the steps very small to keep the accuracy of the path which results in a massive postprocessed file.
Regards
Re: simGetPathCtrlPoint
we have slightly modified the way the simGetPositionOnPath and simGetOrientationOnPath functions operate. If you need the position/orientation at the exact position of a path control point, specify following for the relativeDistance argument:
relativeDistance=-ctrlPtIndex-1
The change will be available in next release (V3.2.0) scheduled to be out by the end of the month.
sneaker
Post by sneaker »
Awesome, thank you!!
