Hi everybody,
I would like a copy of the source code for the webcam model (as the message indicates when you add the model to your enviorment), so I can attempt to port it to Linux Ubuntu 12.04.
I wasn't able to find it in the programming/ subdirectory -- did I overlook the files, or has the source code been removed since this post: viewtopic.php?f=9&t=1333#p5063
Best,
-Lj
Webcam Model Source Code
Re: Webcam Model Source Code
the project files are located in programming/windowsOnlyProjects/v_repExtCam, which is only available in the Windows version of V-REP.
You can also find it here.
