I have a csv file filled with 3d position coordinates.
I am trying to import this as a path into my vrep scene so I can see the path and compare it to subsequent trials of my simulation.
However, when I run 'File->Import->Path from CSV...' I do not get any additional dialog and there is no path object created in my scene. I have also tried adding a path and then with it selected, import the csv and I am not getting any results etiher way.
Am I missing something? The informaiton page on importing is lacking a lot of depth (http://www.coppeliarobotics.com/helpFil ... Export.htm).
Import Path - Help
Re: Import Path - Help
how does your CSV file look like? No dialog is supposed to pop open.
Try with a simple:
saved as testPath.csv, this works.
Try with a simple:
1,1,1
1,2,1
2,2,1
2,1,1
