hi... i already read bubblerob tutorial and somehow i dont understand why my inverted pendulum disintegrate.
here i attach my scene. please let me know what's wrong with my scene
thanks.
https://www.dropbox.com/s/4mb0si3bjyewz ... m.ttt?dl=0
Inverted Pendulum
Re: Inverted Pendulum
you have several problems in your construction. Make sure to carefully read and understand this page.
- your joints are not dynamically enabled. Set them into force/torque mode, then enable the motors (if you wish) and their position control (if you wish).
- object IP_Platform is static. Make it non-static.
- your hierarchy is wrong. It should be:
IP_Platform --> Revolute_joint1 --> dynamic_stick
--> Revolute_joint0 --> dynamic_ban_kiri
--> Revolute_joint --> dynamic_right_wheel
