I'm trying to export a collada animation from vrep with the collada import/export plugin,
in order to create a fancy rendered animation with a 3d modeller+renderer.
I can save my collada file just fine,
but when I try to open it in maya, it crashes, and so does 3dsMax.
In blender I get the geometry at least, but it looks like a single frame, not an animation.
And yes, I did use the "export animation" option in the plugin dialog.
I'm wondering if anyone has ever successfully managed to open a collada animation (exported from v-rep) somewhere else, and if so, what software has been used.
I've searched the forum, the only similar request I've found was this one, but it's not very helpful.
viewtopic.php?f=9&t=1465&p=5579&hilit=collada#wrapper
Any hints would be greatly appreciated,
thanks,
raimund
collada animation export, anyone?
Re: collada animation export, anyone?
Hello Raimund,
you are right, the animation exporter has a bug somewhere. If you dare to have a look at the source code, it is located in programming/v_repExtCollada. The part of interest is located in file colladadialog.cpp, in function simulationAboutToStart(), renderingPassAboutToBeCalled() and simulationEnded().
