I have a simulation running perfectly via the Matlab API. The problem is, when I am in the video recording mode, I am unable to change the camera view angle from my mouse button, that is, I am not able to perform "camera rotate". "Camera pan" works just fine.
While not in video recording mode though, both "camera pan" and "camera rotate" work perfectly.
Is there something I am doing wrong or something option I have to enable?
Thanks in advance.
EDIT: The "camera rotate" does work, but I am unable to rotate about a random point in the scene while in video recording mode. I can only rotate about the current camera position. Hope that makes sense.
Kind regards,
Anuj
Video Recording - Camera Rotate
Re: Video Recording - Camera Rotate
Hello Anuj,
can you try to enable/disable the model browser and/or the scene hierarchy? Does it make a difference? There is a bug that makes the mouse behave as you describe it, and it is corrected for next release.
Yes, it works perfectly when I enable the model browser (with the scene hierarchy still turned off).
Thank you!
To think of it, I had this problem only when I disabled the model browser and the scene hierarchy. I will update the software right away.
Kind regards,
Anuj
Thank you!
Kind regards,
Anuj
Anuj,
the current version still has the bug. It will be corrected in next release (V3.2.2).
