Rotation of a Body (Roll Pitch)
DannyYeong
Post by DannyYeong » 07 Jul 2015, 18:21
I'm trying to implement a roll pitch rotation on a body. For the moment I'm using simSetJointTargetVelocity to manipulate the rotation. Are there other ways to control the revolute joint's rotation angle/velocity under a non threaded script? I'm trying to make a "swinging motion" like a real quad that's achieving balance after moving. My file is below:
http://www.filedropper.com/orientationbodytest
My coding part for the rotation is below (also included in the file script):
------------------------------------------------------------ RP-Orientation------------------------------------------------------------
	posnew=simGetObjectPosition(body,-1)
	posnew1=simGetObjectPosition(target,-1)
	posnew[2]=math.sqrt(posnew[2]*posnew[2])
	posnew[1]=math.sqrt(posnew[1]*posnew[1])
	posnew1[2]=math.sqrt(posnew1[2]*posnew1[2])
	posnew1[1]=math.sqrt(posnew1[1]*posnew1[1])
	mathdiff=posnew1[2]-posnew[2]
	mathdiff1=posnew1[1]-posnew[1]
		if mathdiff>0.075 then
			Vroll=-0.075
		elseif mathdiff<-0.2 then
			Vroll=0.075
			Vroll=0
	simSetJointTargetVelocity(roll,Vroll)
Re: Rotation of a Body (Roll Pitch)
Post by coppelia » 08 Jul 2015, 17:02
as far as I understand it, you want to control your joint in position, not in velocity or torque. If this is the case, make sure your joint is in force/torque mode, the motor enabled, and the control loop enabled too. Then set the desired position with simSetJointTargetPosition.
