Joint Position Change after Running RemApi in matlab
Posted: 29 Jul 2015, 20:31
I have made a structure in the VREP environment having two revolute joints. I connected to VREP from MATLAB using remApi functions. I have to update the joint positions from MATLAB. My MATLAB script successfully does that but as my script ends in MATLAB, the joint ("joint_right") acquires a -180 degree position in VREP and keeps that even if I change that manually from the joint properties dialog. My joint type is inverse kinematic with Hybrid Operation.
Kindly guide me what should I do.
Links to my files are as follows:
VREP file: https://drive.google.com/file/d/0B2w3mm ... sp=sharing
Matlab script: https://drive.google.com/file/d/0B2w3mm ... sp=sharing
Thanks,
Umer
Thanks,
Umer
