how read data from Serial Port?
MEsher
Post by MEsher » 26 May 2013, 10:43
I misunderstood the description "blockingOperation" in the function simSerialRead. My simple topic:
if (buttonID==5) then
	countSendChar=simSerialSend(comHandle, simGetUIButtonLabel(ui, 5))
	if (countSendChar==-1) then simSetUIButtonLabel(ui,8,"N")
		simSetUIButtonLabel(ui,8,countSendChar)
		countReadChar=simSerialCheck(comHandle)
		if (countReadChar==-1) then
			simSetUIButtonLabel(ui,9,"N")
			simSetUIButtonLabel(ui,9,countReadChar)
			getString=simSerialRead(comHandle, countReadChar+1, (1~=1),'',0)
			if (getString==-1) then simSetUIButtonLabel(ui,6,"NOT")
			else simSetUIButtonLabel(ui,6,getString)
I insert TRUST instead of "blockingOperation", but and with NIL the function does not display anything.
Thanks Google Translated for my English
Re: how read data from Serial Port?
Post by coppelia » 26 May 2013, 11:59
I guess your child script runs non-threaded.
I would do it like that:
      if (countReadChar<=0) then
         getString=simSerialRead(comHandle, countReadChar, false,'',0)
MEsher
Post by MEsher » 26 May 2013, 16:15
Thahks for calligraphy code.
Сheers
Don't get too excited:)
What character ends the message from function simSerialSend(comHandle, STRING).
It does not work with standard transfer for AT-commands of phones or MDrive (stepping motor).
How do I replace at the end of 'NULL'(0x00) to 'LF'(0x0A') character for correct transfer.
Post by coppelia » 27 May 2013, 09:55
Hum... Google translate is not that good as it seems ;)
To send special chars at the end of a string, try:
myString="Hello"
myString=myString..string.char(42)
myString=myString.."World"
The result will be Hello*World
