Velocity on MATLAB
STata
Velocity on MATLAB
Post by STata » 22 Feb 2016, 14:32
Dear all,
Is it possible to directly get joint velocity from VREP using MATLAB Api??.
Thanks,
Shravan
Re: Velocity on MATLAB
Post by coppelia » 22 Feb 2016, 17:25
you cannot directly do that. But what you can do is something like:
[ret, retInts, retFloats, retStrings, retBuff]=vrep.simxCallScriptFunction(clientId,"objectName",vrep.sim_scripttype_childscript,"getJointVelocity",[],[],['jointName'],[],operationMode);
velocity=retFloats(1);
Then, in your scene, create a non-threaded child script that you attach to object objectName and put following function at the top of the script:
getJointVelocity=function(inInts,inFloats,inStrings,inBuffer)
    local jointHandle=inFloats[1]
    local res,v=simGetObjectFloatParameter(jointHandle,sim_jointfloatparam_velocity)
    return {},{v},{},''
What will basically happen: the remote API client will remotely call script function getJointVelocity, which will execute the command and return the desired value. This approach can basically be used for all commands that are not directly supported on the client side.
Make sure you have the last V-REP release (V3.3.0), otherwise you won't have that functionality.
