Tutorial: Building a clean model tutorial
martin
Post by martin »
Hello everybody,
I'm new to V-REP and I have a very newie question but I don't find this. In the tutorial, it is explained how to simplify a mesh, but I can't find the options "Decimate the mesh" and "Remove the inside of the mesh", which appears in the tutorial:("Decimate the mesh: allows to reduce the number of triangles contained in the mesh. The function can be accessed with [Menu bar --> Edit --> Decimate selected shape...].")
I can't find it on the "Menu bar-->Edit-->Decimate selected" or "Menu bar-->Edit-->Extract inside of selected shape"
Have these commands changed their name? Is this problem due to my version?
I'm using W8.1, a V-REP PRO EDU version 3.2.2 revision 1, built 5 september 2015.
Thanks in advance, regards!
jokla
Re: Tutorial: Building a clean model tutorial
Post by jokla »
This function was added from V-REP V3.2.3 (November 24th 2015).
See http://www.coppeliarobotics.com/helpFil ... .htm#3.3.0.
Try to download a newer version.
martin
Post by martin »
Correct.
I install the new version and this commands appear.
Many thanks!
