SDF Import Plugin
mgdbgj
SDF Import Plugin
Post by mgdbgj » 06 May 2016, 15:19
Since Gazebo is "abandoning" URDF in favor of SDF, ROS is likely to eventually follow suit. I think a SDF Import Plugin or at least SDF to URDF translator, would benefit the community.
Re: SDF Import Plugin
Post by coppelia » 07 May 2016, 11:26
yes, perfectly agree. This should be done for release 3.3.2 hopefully. Beta version of release 3.3.1 should be out in 2-4 days.
mgdbgj
Post by mgdbgj » 13 Dec 2016, 21:55
It's not clear how SDF importer handles imports and it is not clear how to monitor its progress or check for the errors, for example, when I imported the model that works in Gazebo 7:
- Even though the Convex decompose option was checked in the importer, neither of the collision links was morphed into a convex shape. At no point, convex decomposition dialog was shown.
- The inertial information does not seem to be imported and none the collision links are marked as respondable .
Is there a log I'm missing? Or is there documentation that states which SDF tags are being imported?
Thanks.
Post by fferri » 15 Dec 2016, 10:00
You can see a sort of log of import operations by recompiling the plugin with debug information (i.e. qmake v_repExtSDF.pro followed by make debug).
The convex decomposition dialog option is not currently used.
The inertial information is actually imported (check v_repExtSDF.cpp line 758).
