Compile V-REP on Ubuntu Xenial, i386
dpas
Post by dpas » 13 Jun 2016, 15:11
Compiling V-REP on Ubuntu Xenial 16.04, i386, Qt5.5.1 stops on make with an error with 'CCollDistInterface'. Until the function qdlgabout.cpp there is no message of error.
-I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o qdlgabout.o
sourceCode/gui/dialogs/qdlgabout.cpp
sourceCode/gui/dialogs/qdlgabout.cpp: In member function ‘virtual void CQDlgAbout::initializationEvent()’:
sourceCode/gui/dialogs/qdlgabout.cpp:70:6: error: ‘CCollDistInterface’ has not been declared
if (CCollDistInterface::initializeFunctionsIfNeeded())
Makefile:27468: recipe for target 'qdlgabout.o' failed
make: *** [qdlgabout.o] Error 1
what would you advise to check first to pass through this error?
Re: Compile V-REP on Ubuntu Xenial, i386
Post by coppelia » 15 Jun 2016, 07:07
here again, you need to replace
with
CPluginContainer::isMeshPluginAvailable()
dpas
Post by dpas » 16 Jun 2016, 09:41
Thank you for your answers. It's a real pleasure to communicate and leave our trace here.
Now, the answer is not all you need as on changing to CPluginContainer check, make says that "CPluginContainer has not been declared" there.
 -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o qdlgabout.o sourceCode/gui/dialogs/qdlgabout.cpp
sourceCode/gui/dialogs/qdlgabout.cpp:70:6: error: ‘CPluginContainer’ has not been declared
  if (CPluginContainer::isMeshPluginAvailable())
thank you for your advise.
Post by coppelia » 16 Jun 2016, 09:45
Add following at the top of your file:
#include "pluginContainer.h"
dpas
Post by dpas » 16 Jun 2016, 19:46
with these small changes, and
even as as I had to copy the SciLexer.h into the /sourceCode/gui/scintillaRelated/ folder, while INCLUDEPATH for SciLexer.h is OK (boggles mind why)
v-rep 3_3_1 compiles on ubuntu xenial 16.04, i386, Qt version 5.5.1 with no error.
Thank you for you help!
