Command windows when running V-REP
neshom
Post by neshom »
Is there any way to hide the black command windows when running V-REP with -h command (no GUI mode)?
Thanks in advnace
Re: Command windows when running V-REP
do you mean the terminal window from where you launch V-REP? This is probably possible, but that would be not directly handled by V-REP. Have a look here for instance. For Windows there must be a similar approach. Other than this, you will have to recompile V-REP's main client application (i.e. vrep.exe, located in programming/v_repClientApplication) and remove following line from the Qt project file:
CONFIG += console
