Friction in a non-motor-enabled joint
MattDerry
Post by MattDerry » 11 Jul 2013, 20:05
I'm continuing in my saga towards actually being able to grasp the handle of the crank for the project I'm working on. I have the model dynamics working pretty well on the arm itself, but now I'm looking at the crank that is to be turned. It's basically 3 links with 2 joints that don't have the "motor enabled" checkbox checked. I'm wondering if there is a way I could increase the rotational friction in these joints without enabling them? I saw the "Engine Specific Properties" dialog, but I'm not sure what those parameters do and I've only had marginal success in finding the answers. Thanks in advance!
Regards,
Matt
Re: Friction in a non-motor-enabled joint
Post by coppelia » 11 Jul 2013, 22:56
Hello Matt,
just turn the motor on (Motor enabled), make sure the control loop is disabled (leave unchecked Control loop enabled), set a Target velocity of 0, and adjust the force torque (Max. torque/force) until you have the desired friction.
