detectionState Proximity sensor C++
jegovila
Post by jegovila » 20 Jul 2013, 22:00
Hello
When I use a proximity sensor with Matlab, I use this API function:
[number errorCode,boolean detectionState,array detectedPoint,number detectedObjectHandle,array detectedSurfaceNormalVector]=simxReadProximitySensor(number clientID,number sensorHandle,number operationMode)
So the "detectionState" is a return value and I can use it directly as an argument for a conditional. This works great.
The problem is when I want to do the same with C++. In C++ the API functon is:
simxInt simxReadProximitySensor(simxInt clientID,simxInt sensorHandle,simxChar* detectionState,simxFloat* detectedPoint,simxInt* detectedObjectHandle,simxFloat* detectedSurfaceNormalVector,simxInt operationMode)
And the return value is a remote API function error code.
How can I get the detectionState of my sensor in C++?
Can I do this?
simxReadProximitySensor(clientID,mySensor,0,NULL,NULL,NULL,simx_opmode_oneshot)
And I will get "true" when no detection?
Thanks!
Re: detectionState Proximity sensor C++
Post by coppelia » 22 Jul 2013, 00:01
From C/C++, use the simxReadProximitySensor from the remote API like this:
simxChar detectionState;
simxFloat detectedPoint[3];
simxInt detectedObjectHandle;
simxFloat detectedSurfaceNormalVector[3];
simxInt errorCode=simxReadProximitySensor(clientID,sensorHandle,&detectionState,detectedPoint,&detectedObjectHandle,detectedSurfaceNormalVector,operationMode);
if (detectionState!=0)
    // something was detected
If you just need the detection state, then you can set the 4th, 5th and 6th arguments to NULL.
Make sure you read this section on how the remote API works.
