Spherical Joint as 3 Revolute Joints
riczan
Post by riczan » 21 Mar 2017, 11:11
I need to create a spherical joint as a cascade of 3 revolute joints, but if I do it as explained here http://www.coppeliarobotics.com/helpFil ... iption.htm, it doesn't work, there is no way to connect 2 shapes. I tried all the control modes on the 3 the joints and almost any other setting, but nothing. Can you tell me how to do it please?
Re: Spherical Joint as 3 Revolute Joints
Post by coppelia » 22 Mar 2017, 13:41
if you want to do a dynamic simulation, where your shapes have mass and inertia, then you need to carefully follow the rules from this page.
So instead of having following:
shape1 --> joint1 --> joint2 --> joint3 --> shape2
you need to have something like:
shape1 --> joint1 --> auxShapeA --> joint2 --> auxShapeB --> joint3 --> shape2
riczan
Post by riczan » 29 Mar 2017, 10:38
Ok, thanks.
