End-effector not following
paredespro
Post by paredespro »
Hi there,
Im having some troubles with a simulation, i have created both dummies, target and tip to follow a path, but once i run the simulation the robot arm does not move at all while the dummy (target) follow the path, any ideas how can i fix this?
Re: End-effector not following
can you share your scene file? It will be easier to look at what the problem is.
paredespro
https://www.dropbox.com/s/ydygad0wz9y67 ... n.ttt?dl=0
here is the scene i have created
Your joints are currently in Force/torque mode. This will not work out of the box if you use IK on the kinematic chain.
So you should set all robot joints in hybrid IK mode. Then, following will happen: the IK calculated joint angles will be used as target positions for the joints that are in position control.
At the same time, the IK resolution method is DLS, so the IK will be highly damped and relatively slow. Not sure if this is intentional. If you use the pseudo inverse method, then there won't be any damping anymore, but then you need to make sure the constraints on the robot are correctly set.
paredespro
Thanks a lot, now at least is following the target, it does some crazy movements and goes through the railway wheel ( not smooth at all) but at leasst now is following.
Do you know also, why is the Omnirob not stopping once the prox sensor detects the wheel?
Thanks a lot for the help.
Did you code a reaction behaviour for when the proximity sensor is detecting something? How are you stopping the omni-wheels?
