Update links to beta version
emeres
Post by emeres »
Update the links to beta version.
**link removed** is a 404. The latest beta, I assume, rev9 is reachable under **link removed**.
Re: Update links to beta version
Thanks, but this is a too early beta and not meant to be downloaded yet (not stable enough).
emeres
Post by emeres »
What are the latest commits for version 3.3.2 for both https://github.com/fferri/v_repStubsGen and https://github.com/fferri/v_repExtRosInterface then? I'm using a modified version of installation script for Ubuntu 14.04 from here, the vrep_system_install.sh http://www.irccyn.ec-nantes.fr/~kermorg ... ml#scripts. The modified version is here: https://pastebin.com/4g7eY1Hu. I can compile the ROS plugin for 3.4.0 with it, but would rather revert to 3.3.2 for now. The source is cloned to latest commit as you can see, so the ROS plugin wants 3.4.0 rev9.
You may use that early beta version. And if you use the last RosInterface plugin from the the gitHub, then you won't have a choice and you will have to use the revision9 of release 3.4.0.
or checkout a previous version. a version of a month ago will work with older V-REP.
