Plotting a variable in a graph (from a ROS node)
mthor13
Post by mthor13 » 21 Jul 2017, 15:58
I want to plot a variable (received from a C++ ROS node) in a graph, but I am having some issues.
I get the following error message:
Lua runtime error: [string "[embScript_47452005.lua] SCRIPT hexapod"]:147: Invalid data stream. (sim.setGraphUserData)
stack traceback:
[C]: in function 'setGraphUserData'
...EP_PRO_EDU_V3_4_0_Linux/lua/hexapod_child_script.lua:147: in function '__scriptCodeToRun__'
/home/mat/V-REP_PRO_EDU_V3_4_0_Linux/lua/sim.lua:19: in function 'include'
[string "[embScript_47452005.lua] SCRIPT hexapod"]:1: in main chunkck:
This is what is currently have:
function CPGOutput_cb(msg)
    data=msg.data
    sim.setGraphUserData(graphHandle, "CPG_output", data)
if (sim_call_type==sim.childscriptcall_initialization) then
    graphHandle=sim.getObjectHandle("Graph")
Is it even possible to plot just a float variable?
SOLUTION:
    data = msg.data
    sim.setStringSignal("CPGOutput_signal",data)
if (sim_call_type==sim.childscriptcall_sensing) then
    signalData=simGetStringSignal("CPGOutput_signal")
    simClearStringSignal("CPGOutput_signal")
    if signalData then
        print(signalData)
        print("\n")
        simSetGraphUserData(graphHandle,"CPGOutput_stream",signalData)
Best Regards,
Mathias Thor
Re: Plotting a variable in a graph (from a ROS node)
Post by coppelia » 25 Jul 2017, 20:45
Hello Mathias,
Are you sure your data stream type is "Various: user-defined"?
Also, make sure to check this link.
Otherwise you can always open a custom user interface window and draw the curve manually (i.e. where you control every aspect of the graph). For that, you can find inspiration in the demo scene customUI.ttt
mthor13
Post by mthor13 » 14 Feb 2018, 16:03
Thanks!
Worked for me.
