Permanently Removing Objects from Simulation?
Matt
Post by Matt » 27 Sep 2017, 19:46
Hi there,
I have an application where I'm adding / removing hundreds of different objects from a V-REP scene, but finding that although an object can be "removed" from the scene, data still persists in memory which eventually ends up maxing out my RAM. Here's a snippit that'll reproduce it, where Cap.stl is from https://free3d.com/download-page.php?url=sport-cap-6044
while simGetSimulationState()~=sim_simulation_advancing_abouttostop do
    local object = simImportShape(4, 'Cap.stl', 1+2, 0.01, 1.)
    simSwitchThread()
    simRemoveObject(object)
Is there a known workaround for this?
Thanks!
Matt
Re: Permanently Removing Objects from Simulation?
Post by coppelia » 29 Sep 2017, 18:49
Hello Matt,
you discovered a memory leak with the import function. You can work around it by importing the item once, then simply copy/pasting it as needed (if the object is always the same):
local a=sim.getObjectHandle('Shape')
    local objects = sim.copyPasteObjects({a},0)
    simSwitchThread()
    simRemoveObject(objects[1])
Matt
Post by Matt » 30 Sep 2017, 03:51
Thanks for the confirmation. I'll see what I can do to avoid loading different objects too frequently in the meantime!
Matt
