How to model a compliant floor? (compliance soft bounce)
dbworth
Post by dbworth »
Hi
Can anyone suggest an approach to modelling a compliant floor please?
I am thinking of surfaces like carpet with soft underlay, or a wooden sprung floor, or closed-cell/open-cell foam.
The affect this has is that your feet sink into the floor, so this can be tricky for a robot that is expecting a perfectly flat floor.
Secondly, walking across these surfaces will cause your feet to roll inwards and the reaction force will not be perfectly vertical.
It would be great if I could model these affects somehow :-)
Any help appreciated.
Re: How to model a compliant floor? (compliance soft bounce)
When using the ODE engine, you can try to play with the Soft CFM and Soft ERP parameters to emulate a soft surface. Those can be found in the engine specific properties in the Shape dynamics dialog.
A more complicated alternative would be to do something similar to what is described in this post.
Finally, we are currently working at supporting a high fidelity physics engine (Vortex) that will support such type of surfaces.
