Calling simxStart through a c++ constructor fails
Rex
Post by Rex » 02 Feb 2018, 08:06
I am writing a C++ client that is trying to dynamically setup multiple Remote API connections to multiple VREP instances with successive port numbers (Starting with 10001). I've written a 'Sim' class that contains each remote connection and associated variables within individual objects. These 'Sim' objects are stored within a vector accessed by the main program.
I'm facing an issue where the clientID and connectionID returned are both -1, if I call simxStart through the Sim class constructor. However, if I call multiple simxStart multiple times directly in a for loop, to each unique VREP instance through the main program directly, the clientIDs returned are valid (0, 1, 2... etc) and connectionID are all 0;
main.c:
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include "sim.hpp"
#include <vector>
using namespace std;
vector<Sim> SimInstances;
char* serverAddress = (char*) "my_host_ip";
int main(){
	int instancenumber;
	int requiredinstancescount = 5;
	for(instancenumber = 0; instancenumber<requiredinstancescount; instancenumber++){
		SimInstances.push_back(Sim(instancenumber,serverAddress));
		cout << "Client ID of instance " << instancenumber << " is " << SimInstances[instancenumber].GetConnectionId() << "\n";
		cout << "Connection ID of instance " << instancenumber << " is " << SimInstances[instancenumber].GetClientId() << "\n";
	return 0;
sim.hpp
#ifndef _SIM_HPP_
#define _SIM_HPP_
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <string.h>
#include <string>
#include <sstream>
class Sim{
private:
	simxInt clientID;
	simxChar* connectionAddress;
	simxInt connectionPort;
	simxUChar waitUntilConnected;
	simxUChar doNotReconnectOnceDisconnected;
	simxInt timeOutInMs;
	simxInt commThreadCycleInMs;
	simxInt connectionID;
public:
	Sim();
	Sim(int instancenumber, char* serverAddress);
	~Sim();
	int GetConnectionId();
#endif
sim.cpp
#include "sim.hpp"
#define STARTPORT 10001
Sim::Sim(){}
Sim::Sim(int instancenumber, char* serverAddress){
	clientID = -1;
	connectionPort = STARTPORT + instancenumber;
	waitUntilConnected = 1;
	doNotReconnectOnceDisconnected = 0;
	timeOutInMs = 5000;
	commThreadCycleInMs = 5;
	connectionAddress = serverAddress;
	connectionID = -1;
	clientID = simxStart(connectionAddress, connectionPort, waitUntilConnected, doNotReconnectOnceDisconnected, timeOutInMs, commThreadCycleInMs);
Sim::~Sim(){
	simxFinish(clientID);
int Sim::GetClientId(){
	return clientID;
int Sim::GetConnectionId(){
	connectionID =  simxGetConnectionId(clientID);
	return connectionID;
here's the code I got working using direct simxStart API call:
void StartSimDirectAPI(){
int instancenumber;
	for(instancenumber = 0;instancenumber<requiredinstancescount; instancenumber++){
		//variable definitions
		simxInt clientID = -1;
		simxInt connectionPort = STARTPORT + instancenumber;
		simxUChar waitUntilConnected = 1;
		simxUChar doNotReconnectOnceDisconnected = 0;
		simxInt timeOutInMs = 5000;
		simxInt commThreadCycleInMs = 5;
		simxChar* connectionAddress = serverAddress;
		simxInt connectionID = -1;
		cout << "Client ID : " << clientID << "\n";
		cout << "Connection ID : " << connectionID << "\n";
Thanks in advance!
Re: Calling simxStart through a c++ constructor fails
Post by coppelia » 04 Feb 2018, 16:39
not sure, there must be a problem with how you create the sim objects...
Rex
Post by Rex » 12 Feb 2018, 05:04
Hi, I've managed to fix the problem. Turns out that if I push the object itself to a vector (as a copied object), the connection to the Sim will break. Instead, it works if I push a pointer of the original object to the vector.
