Weird segfault in liblua (v.3.5.0)
fgolemo
Post by fgolemo » 08 Feb 2018, 17:35
Hey, so I just downloaded the new version of V-Rep and whenever I'm trying to connect via the Python RemoteAPI I get the following error and V-Rep just crashes:
How can I debug this? This is on a fresh installation of (K)Ubuntu 17.10.
EDIT: the same invocation code worked fine with version v.3.4.0.
Plugin 'RosInterface': loading...
Error with plugin 'RosInterface': load failed (could not load). The plugin probably couldn't load dependency libraries. For additional infos, modify the script 'libLoadErrorCheck.sh', run it and inspect the output.
Plugin 'SDF': loading...
Plugin 'SDF': warning: replaced variable 'simSDF'
Plugin 'SDF': load succeeded.
Plugin 'SurfaceReconstruction': warning: replaced variable 'simSurfRec'
Error: signal 11:
libv_rep.so(_Z11_segHandleri+0x28)[0x7fa220068c58]
/lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7fa22412d140]
libv_rep.so(_Z15luaHookFunctionPvS_+0x182)[0x7fa2200c2142]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(+0xbb7b)[0x7fa2252b1b7b]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(+0x165b3)[0x7fa2252bc5b3]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(+0xc61e)[0x7fa2252b261e]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(+0xbd77)[0x7fa2252b1d77]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(+0xbdf5)[0x7fa2252b1df5]
/home/florian/tools/V-REP_PRO_EDU_V3_5_0_Linux/liblua5.1.so(lua_pcall+0x55)[0x7fa2252add35]
libv_rep.so(_ZN16CLuaScriptObject9_luaPCallEPviii+0x1a)[0x7fa22000293a]
And here is the output of libLoadErrorCheck:
florian:V-REP_PRO_EDU_V3_5_0_Linux/ $ ./libLoadErrorCheck.sh        [17:38:37]
        linux-vdso.so.1 =>  (0x00007ffde9bd7000)
        liblua5.1.so (0x00007fdb28479000)
        libqscintilla2.so.9 (0x00007fdb26ed0000)
        libQt5OpenGL.so.5 (0x00007fdb26c79000)
        libQt5Widgets.so.5 (0x00007fdb26448000)
        libQt5Gui.so.5 (0x00007fdb25c9b000)
        libQt5SerialPort.so.5 (0x00007fdb25a82000)
        libQt5Network.so.5 (0x00007fdb256f1000)
        libQt5Core.so.5 (0x00007fdb24fb9000)
        libGL.so.1 => /usr/lib/nvidia-390/libGL.so.1 (0x00007fdb24c7d000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fdb24a5e000)
        libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fdb246d8000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fdb24382000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fdb2416b000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fdb23d8b000)
        libQt5PrintSupport.so.5 (0x00007fdb23b1d000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fdb23900000)
        libicui18n.so.56 (0x00007fdb23467000)
        libicuuc.so.56 (0x00007fdb230af000)
        libicudata.so.56 (0x00007fdb216cc000)
        librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fdb214c4000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fdb212c0000)
        libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007fdb210be000)
        libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fdb20daa000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fdb2837e000)
        libnvidia-tls.so.390.12 => /usr/lib/nvidia-390/tls/libnvidia-tls.so.390.12 (0x00007fdb20ba6000)
        libnvidia-glcore.so.390.12 => /usr/lib/nvidia-390/libnvidia-glcore.so.390.12 (0x00007fdb1edfb000)
        libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fdb1eac2000)
        libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fdb1e8b0000)
        libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fdb1e63e000)
        libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fdb1e417000)
        libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fdb1e213000)
        libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fdb1e00d000)
        libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007fdb1ddf8000)
EDIT2: I also installed Ubuntu's liblua5.1, removed the one shipped with V-Rep and copied over the system one into the V-Rep directory, but that didn't help either.
Re: Weird segfault in liblua (v.3.5.0)
Post by coppelia » 08 Feb 2018, 18:32
to me it seems that it is crashing at V-REP start-up, when it tries to load the surface reconstruction plugin...
Did you try to remove that plugin and see if that changes anything? The plugin is the file libv_repExtSurfaceReconstruction.so.
From the console output, I don't see the link to Lua or the remote API...
Valed
Post by Valed » 30 Mar 2018, 07:06
I'm getting a similar error trying to run the latest version of V-REP on Ubuntu 18.04:
vlad@vlad-UX331UN:~/Documents/V-REP_PRO_EDU_V3_5_0_Linux$ ./vrep.sh
XmbTextListToTextProperty result code -2
Error: signal 11:
/home/vlad/Documents/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_Z11_segHandleri+0x28)[0x7f9032d54878]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f9036e7ff20]
Removing the .so you suggested doesn't help. Crashes on startup..
Any ideas?
Thanks!!
Valed
Post by Valed » 02 Apr 2018, 05:37
Decided to move back to to 16.04. Everything works there. Cheers!
fabro
Post by fabro » 05 Sep 2018, 19:26
Dear all,
Not sure it would help, but I've managed to run VREP 3.5.0 rev4 on Ubuntu 18.04. See viewtopic.php?f=5&t=7288&p=29472#p28740
