Ballbot and Controller
pedrophj
Post by pedrophj » 06 Mar 2018, 14:05
Hello everyone,
I am studying the ballbot model in V-REP. Could someone help me understand it?
    local l=math.sqrt(v[1]*v[1]+v[2]*v[2]+v[3]*v[3])
    local ls=l
    local w=0.18
    v[1]=v[1]*ls*w/l
    v[2]=v[2]*ls*w/l
    v[3]=v[3]*ls*w/l
I understand that v[1]=v[1]*ls*w/l it is the same as v[1]=v[1]*w, because above the author did ls = l. Right ?
  local m=simGetObjectMatrix(sens,-1)
    local euler=simGetEulerAnglesFromMatrix(m)
    euler[1]=0
    euler[2]=0
    local m2=simBuildMatrix({0,0,0},euler)
    local m3=simGetInvertedMatrix(m2)
     local vect={m[3],m[7],m[11]}
    vect=simMultiplyVector(m3,vect)
    v=simMultiplyVector(m3,v)
    velo=simMultiplyVector(m3,velo)
    d=0.2
I researched and the elements 3, 7, 11 are position.
What are the variables vect, velo, d and v ?
Which controller is being used ?
Re: Ballbot and Controller
Post by coppelia » 07 Mar 2018, 11:26
the controller is a very simple proportional controller, as far as I remember. It is meant as a simple example. You can (and should!) write a much better controller.
pedrophj
Post by pedrophj » 07 Mar 2018, 20:06
Thanks for answering me.
So, the code that calculates the angular velocity of the actuator is this below (variable v).
The variable "velo" is the absolute velocity of the robot.
The gain of the controller is 200, but I did not understand the "dir" (direction) and also I do not know what "vect" is.
I need to understand well the measured variables to be able to implement a new controller.
   vect[1]=vect[1]-v[1]+velo[1]*d
    vect[2]=vect[2]-v[2]+velo[2]*d
    local v=-math.sqrt(vect[1]*vect[1]+vect[2]*vect[2])*200
    local dir=math.atan2(vect[1],vect[2])+1*math.pi/2
    setBallMotion(v,dir,0)
Post by coppelia » 08 Mar 2018, 08:47
From what I can tell, the controller looks at the Z-vector component of the Ballbot's reference frame (object BallRobot_sensorPosition) to determine the amount and direction of inclination.
pedrophj
Post by pedrophj » 08 Mar 2018, 14:49
Thanks for helping me. Now I can design an LQR or PID controller.
