communication problem between vrep_ros_interface and ros node
mariam314
Post by mariam314 » 10 Apr 2018, 11:44
I have a manipulator model in vrep and I am using the ros interface (let's call it node 1) to publish information and subscribe to topics from my c++ ros node (node 2). The problem is: There seems to be kind of a bug, because if I open node 1 first and then node 2, only node 2 receives the data and the subscriber of node 1 seems to be asleep when node 2 gets activated. The same thing happens also the other way around (node 2 gets turned on first, so it doesn't subscribe to the topics of node 1).
This issue is very annoying, because I can't let both nodes communicate both ways in real time.
It's worth to note that sometimes it works perfectly fine (usually the first time I boot my computer and open both terminals). Until now I haven't found a cause why it sometimes works and why it doesn't most of the time.
I'd be really happy to solve this issue!
Thanks,
Mariam
Re: communication problem between vrep_ros_interface and ros node
Post by coppelia » 12 Apr 2018, 07:56
I strongly suspect this is directly linked to ROS (but I am not saying this is an issue, probably more a problem linked to how ROS is used/configured).
