Any data after dynamics change
mamagosia
Post by mamagosia » 15 Apr 2018, 17:31
I have a simulation with Quadricopter.ttm. When I use this model without any changes (dynamics), but with lots of proximity sensors, it moves correctly. But when I change dynamics, only for few seconds of simulation proximity sensors' data are sent to my python script. And after that there are not data from sensors. I use Newton engine, because with only this engine doesn't break my model. Does dynamics have an influence for data sending?
Re: Any data after dynamics change
Post by coppelia » 16 Apr 2018, 07:00
not really sure what is happening in your scene. Could it be that your visible and non-visible parts in the scene are not overlapping?
Best would be to post a simplified scene that illustrates the problem.
mamagosia
Post by mamagosia » 16 Apr 2018, 12:16
Here is my project: https://drive.google.com/open?id=1Wz1ab ... Hk0mOVsqBm
Open scene.ttt and in a terminal write: $ python UAV_main_bra1uav.py (it starts simulation)
In this scene quadricopter moves to the goal (red sphere). But when I change dynamics of it like in the sceneAfterModifications.ttt , a few seconds after simulation starts, the quadricopter "doesn't see" obstacles and V-REP doesn't send sensors' informations. So I have got an error in the terminal - this error is included in my project's folder.
I use Ubuntu 16.04 and V-REP Pro Edu 5.3.0
Post by coppelia » 17 Apr 2018, 17:16
Please post a minimalistic, if possible self-contained scene that illustrates your situation. We can't debug whole projects for you, that is not the purpose.
mamagosia
Post by mamagosia » 17 Apr 2018, 20:38
I haven't got a self-contained scene, I send you the minimum to illustrate my problem. I can't show my problem without pythons' scripts, because they contain everything for Quadricopter - path, collision avoidance (I use proximity sensors for it, so they are very necessary!).
Post by coppelia » 18 Apr 2018, 09:08
we cannot afford to read through your project, that also includes several files. That's too much effort. Also, from your explanation it seems that you have a communication problem, rather than a V-REP sensor problem. So check if some other messages are still passing through, or if your remote API is hanging as a whole.
mamagosia
Post by mamagosia » 18 Apr 2018, 11:54
I don't want you must check my scripts, but only run them, because only with them my problem is illustrated.
The problem is following: I have got the same pythons' scripts for original quadricopter model and the same I use for model with other dynamics. And I just want know how it is possible that V-REP doesn't send data correctly to pythons' scripts after dynamics change.
Post by coppelia » 19 Apr 2018, 08:24
Your problem is not illustrated by simply running your scene: you say that V-REP doesn't send sensor information after some time: how is that illustrated by just running the scene? How is the sensor information sending process illustrated/visualized?
When sending data, many things can go wrong on the way. Of course it could be directly a bug in the remote API, but it is very more likely that your remote API client is doing something wrong at some point. And to check that, you need to debug your remote API client or provide a minimalistic scene that we can debug.
