simxCallScriptFunction received corrupted object handle
Rex
Post by Rex » 16 Apr 2018, 05:07
While calling the remote API simxCallScriptFunction from a C++ program to create pure shapes in VREP, the object handle getting returned to the C++ program is occasionally different from the actual shape's handle.
The shape handle created by the lua script in VREP was 65, but 1987208531 was returned to the C++ program.
For shapes with handles 64 and 66, the handle returned to the C++ program was correct. They were called through the same C++ code in a for loop.
Can someone kindly shed some light on why this is happening? Thanks.
Here's the API call code I used:
int Sim::CallScriptFunction(const char* functionName, int inIntCnt, const int* inInt, int inFloatCnt, const float* inFloat, int inStringCnt, const char* inString, int inBufferSize, const unsigned char* inBuffer, int* outIntCnt, int** outInt, int* outFloatCnt, float** outFloat, int* outStringCnt, char** outString, int* outBufferSize, unsigned char** outBuffer){
	std::mutex mtx;
	mtx.lock();
	const char* scriptDescription = "remoteAPICommandServer";
	int scriptHandleOrType = sim_scripttype_childscript;
	int operationMode = simx_opmode_blocking;
	int functionCode = 0;
	int timeoutcounter = 0;
	do{
		functionCode=simxCallScriptFunction(clientID, scriptDescription, scriptHandleOrType, functionName, inIntCnt, inInt, inFloatCnt, inFloat, inStringCnt, inString, inBufferSize, inBuffer, outIntCnt, outInt, outFloatCnt, outFloat, outStringCnt, outString, outBufferSize, outBuffer,operationMode);
		cout << "simxCallScriptFunction return code: " << functionCode << endl;
		if(functionCode&1<<0){timeoutcounter++; usleep(200);}
	}while(functionCode&1<<0 && timeoutcounter<=timeout);
	usleep(5000);
	mtx.unlock();
	return functionCode;
Here's the lua function used:
function CreatePureShape_function(inInts,inFloats,inStrings,inBuffer)
    -- -- take note that lua array indexes start at 1!
    -- -- inInts[1]: primitiveType
    -- -- inInts[2]: shapeoptions
    -- -- inFloats[1]: shape x dimension
    -- -- inFloats[2]: shape y dimension
    -- -- inFloats[3]: shape z dimension
    -- -- inFloats[4]: shape x position
    -- -- inFloats[5]: shape y position
    -- -- inFloats[6]: shape z position
    -- -- inFloats[7]: shape's alpha orientation
    -- -- inFloats[8]: shape's beta orientation
    -- -- inFloats[9]: shape's gamma orientation
    local primitiveType = inInts[1]
    local shapeoptions = inInts[2]
    local sizes = {inFloats[1], inFloats[2], inFloats[3]}
    local position = {inFloats[4], inFloats[5], inFloats[6]}
    local orientation = {inFloats[7], inFloats[8], inFloats[9]}
    --calculate mass based on density of 1000kg/m^3
    local mass = sizes[1]*sizes[2]*sizes[3]*1000
    local shapehandle
    local functionCode
    sim.addStatusbarMessage("Creating cuboid")
    --create the shape
    shapehandle = simCreatePureShape(primitiveType, shapeoptions, sizes, mass, nil)
    shapename = simGetObjectName(shapehandle)
    sim.addStatusbarMessage(shapename)
    --print orientation of shape to be set
    sim.addStatusbarMessage("Dimensions:")
    sim.addStatusbarMessage(sizes[1])
    sim.addStatusbarMessage(sizes[2])
    sim.addStatusbarMessage(sizes[3])
    --return error code if shape was not successfully created
    if shapehandle == -1 then
        sim.addStatusbarMessage("Could not create shape...")
        return {-1, shapehandle},{},{},''
    sim.addStatusbarMessage("Shape Handle:")
    sim.addStatusbarMessage(shapehandle)
    -- sleep(3)
    sim.addStatusbarMessage("setting shape position")
    --print position of shape to be set
    sim.addStatusbarMessage(position[1])
    sim.addStatusbarMessage(position[2])
    sim.addStatusbarMessage(position[3])
    --set position the shape
    functionCode = simSetObjectPosition(shapehandle, -1, position)
    if functionCode >1 then
        sim.addStatusbarMessage("Failed to position shape...")
    sim.addStatusbarMessage("setting shape orientation")
    sim.addStatusbarMessage(orientation[1])
    sim.addStatusbarMessage(orientation[2])
    sim.addStatusbarMessage(orientation[3])
    --orientate the shape
    functionCode = simSetObjectOrientation(shapehandle, -1, orientation)
        sim.addStatusbarMessage("Failed to orientate shape...")
        sim.addStatusbarMessage(functionCode)
    return {0, shapehandle},{},{shapename},''
VREP console
C++ program printout
Re: simxCallScriptFunction received corrupted object handle
Post by coppelia » 16 Apr 2018, 07:36
please try following and tell me if it works.
Non-threaded child script attached to object dummy:
function test_function(inInts,inFloats,inStrings,inBuffer)
    cnt=cnt+1
    return {0,cnt},{},{'hello'..cnt},''
    cnt=-1
C/C++ client side:
#include <stdio.h>
#include <stdlib.h>
extern "C" {
    #include "extApi.h"
int main(int argc,char* argv[])
    int clientID=simxStart((simxChar*)"127.0.0.1",19997,true,true,2000,5);
    if (clientID!=-1)
        printf("Connected to remote API server\n");
        simxStartSimulation(clientID,simx_opmode_blocking);
        int retIntCnt;
        int* retInts;
        int retStrCnt;
        char* retStrs;
        for (size_t i=0;i<100;i++)
            int result=simxCallScriptFunction(clientID,"dummy",sim_scripttype_childscript,"test_function",0,NULL,0,NULL,0,NULL,0,NULL,&retIntCnt,&retInts,NULL,NULL,&retStrCnt,&retStrs,NULL,NULL,simx_opmode_blocking);
            if (result==simx_return_ok)
                printf("RetVal: %i, retInt: %i, retString: %s\n",result,retInts[1],retStrs);
                printf("Remote function call failed\n");
        simxFinish(clientID);
    return(0);
Rex
Post by Rex » 16 Apr 2018, 09:11
Hi, thanks for your help. I've tried your code and the returned data was all correct.
