How to change the graph background color?
xiemzuo
Post by xiemzuo »
Can someone tell me how to change the graph background color? I want to change from the default black to white. I tried to use the Display grids-Adjust background color, but it didn't work.
Mingzuo
Re: How to change the graph background color?
yes, the dialog items are currently not connected to the graph functionality. You can however adjust the color by adjusting the graph script directly and modifying
background-color="x,x,x"
in file lua/graph_customization.lua for instance. This will however change the background color of all graphs, unless you copy the graph code inside of the customization script attached to the graph object.
xiemzuo
Post by xiemzuo »
Thank you a lot
