How to save the object created by simAddDrawingObject into ttt?
Plug
Post by Plug » 10 May 2018, 03:18
I draw some lines by simAddDrawingObject in customization script but fail to save them into ttt(it seems "save scene" doesn't work for such lines), so that when open the vrep and load the ttt next time, these lines disappears.
Is there anyway to same them into ttt? (for example, is it possible to create a point cloud with such drawing object?)
Re: How to save the object created by simAddDrawingObject into ttt?
Post by coppelia » 11 May 2018, 07:56
for point clouds, don't use drawing objects but point clouds directly.
Drawing objects cannot be saved. What you however can do is following:
in the init phase of your script, read the coordinates of lines you have previously drawn, e.g.:
    h=sim.getObjectAssociatedWithScript(sim.handle_self)
    lineContainer=sim.addDrawingObject(sim.drawing_lines,1,0,-1,9999)
    local data=sim.readCustomDataBlock(h,'myLines')
    if data then
        sim.writeCustomDataBlock(h,'myLines',nil)
        data=sim.unpackTable(data)
        drawLines(data)
function drawLines(coordinates)
    if data then
        data={}
    for i=1,#coordinates/6,1 do
        local l={}
        for j=1,6,1 do
            l[j]=coordinates[(i-1)*6+j]
            data[#data+1]=l[j]
        sim.addDrawingObjectItem(lineContainer,l)
    sim.writeCustomDataBlock(h,'myLines',sim.packTable(data))
the line data will be saved together with the object (actually stored inside of the object as a custom data block).
